Collaborate forum
AutoCad’s “Multi line text” doesn’t open up properly
When opening DWG files certain text boxes don’t open up correctly, it seems text done using AutoCad’s “Multi line text” are the ones causing the problem. Text created using AutoCad’s “single line text” opens up fine.
Below is a screen shot showing the problem (left is AC 6.5 R2, right is Autocad 2004) also a screen shot of my opening settings (I’m not using a configuration file)
1 REPLY 1
