Collaborate forum
Autocad In Different Location
Ok…why is this happening….if I export a floor plan from AC to Autocad…..why doesn’t that Autocad file reference to the same point in AC later on….why are we loosing the coincidence of it’s location….this is frustrating....
2 REPLIES 2
TomWaltz
I'm not entirely sure about this, but I have long suspected that having a User Origin set can affect the origin of when creating DWG files.
Tom Waltz
you would have to move the User Origin in that case...what I can't figure out, if export the floor plan out and xref back in, it's not the same spot....if open the autocad file in AC they are coincident....so moving the origin creates and issue should be moved...when bringing back the autocad file....
