Teamwork & BIMcloud
BIM library : new object
I have created new objects and I would like to load them in the Archicad library. Is it possible or must I create a new library ? If necessary, how should I create one ?
Thank you,
BAérangère
4 REPLIES 4
Laura Yanoviak
What version of AC are you using?
AC26 US (5002) on Mac OS Ventura 13.5
I use Archicad 14
Laura Yanoviak
You can either create a Library or embed the part in your project file. Creating a Library is the smart way to go if you'll be using the object in more than one project. Libraries can be loaded and parts embedded via the Library Manager: File > Libraries and Objects > Library Manager...
Thank you very much for your answer !
