Collaborate forum
BIMCloud message
dhnguyen
Recently we upgraded to ArchiCAD 24. A new BIM Server is created and I am able to log in just fine from a browser.
However, I'm getting this message when I try to join a Team Work project, what is the problem and how can we fix it?
DNguyen
ArchiCAD 18- 24
(expert in AutoCAD, novice in ArchiCAD)
Using ArchiCAD since Feb 2017 mostly for 2D, starting to learn 3D.
insideru
If you use BIMCloud Basic, you need to select the AC version you want to work with.
In your browser, go to Servers - then select the server, then to the right select the version and hit save - see attached photo.
ARCHICAD 24 INT
macOS Big Sur
insideru
ARCHICAD 24 INT
macOS Big Sur
dhnguyen
Thank you!
DNguyen
ArchiCAD 18- 24
