BOM lists 2 m2 for material assigned quantity of 1 m2
Hubert Wagner
Hello List :
I've created a test database in AC13.
DB Name
General
Insulation
300 mm FG, qty 1 m2
Panel skins
18 mm OSB, qty 1 m2
10 mm OSB, qty 1 m2
Stringers
#1 joist, qty 1,6 m2
Units
m
m2
m3
pc
I've created a property : testPanel
DB Name Key Code Name Qty Unit Proportion
name 003 005 1,8 mm OSB 1 m2 Surface A
name 004 006 #1 joist 1,6 m2 Surface A
name 002 009 100 mm FG 1 m2 Surface A
name 003 008 1,0 mm OSB 1 m2 Surface A
and assigned the following to a slab :
However, the BOM for a 1 x 1 m test panel shows :
1 m2 for 1,8 OSB
but 2 m2 for 1,0 mm OSB.
If I set the quantity of 1,0 mm OSB to 0,5 it lists correctly as 1 m2
What am I missing here?
Regards : Hubert Wagner
1 REPLY 1
Hubert Wagner
Hello :
I've just discovered the Surface flag of the 1,0 mm item was set to Surface C in the property item. Yet when I set up the DB I chose, or am certain I chose Surface A.
I changed the Surface in the property item and the error has disappeared.
This problem may have been self-inflicted. Yet the data set is so small one cannot help but wonder if there is some oddity in AC, not updating changes immediately for example.
So, question withdrawn.
Learn and get certified!
