Base Quantities for objects?
Mats_Knutsson
I've got a model with 870 suspended ceilings made with EcoPhone zone accessory, curtain wall or slab depending on the complexity. Now I want to check the area of all ceilings and also export IC Base Quantities. (net and gross area of ceiling) The EcoPhone objects doesn't export base quantities. Is there a way to map and expot the EcoPhone areas correctly to IFC? I'm on 21.
/Mats
AC 25 SWE Full
0 REPLIES 0
Learn and get certified!
