Collaborate forum
Beam volume doubled in schedule?
kajnorberg
Hi!
Today I discovered a curious issue when calculating material volumes. All my beams doubled their volume in the schedule. I tried converting them all to morphs and all of them were halved in volume to their correct amount. Why is this happening? It is creating quite a lot of problems for me!
Thank you!
/Kaj
Archicad 23 SWE
Macbook Pro 2017
OS 10.13.6
1 ACCEPTED SOLUTION
4 REPLIES 4
What type of schedule is it - element or component?
Can you post a screen shot of the schedule settings - criteria and fields?
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Solution
James B
I'd also check the schedule scheme, is it checking Beam and/or Beam Segment? It may be checking the Beam and Beam Segment data - may want to add element type is not Beam Segment.
James Badcock
GRAPHISOFT Product Manager
vdentello
The Same applies for Columns. You Have to either select Beam Parts or "Full" Beam, if you calculate volume you have to exclude one of them or you'll get duplicate values.
They actually "coexist" in the model.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
kajnorberg
Ah yes, thank you all! That was it!
I was using the components interactive schedule and hadn't really specified what element types should be included, but it worked if I removed either one of them.
Thanks again!
Archicad 23 SWE
Macbook Pro 2017
OS 10.13.6
