Hi Leticia,
I have only imported a few Sketch-Up files, mostly whole building shells. I used the Merge import method for those. The resulting ‘object’ looks great and seem fairly small in poly count. However, I prefer not to use them for precision modeling work, only general visualization.
For interior objects, I try to find well-made objects and sometimes convert them. In cases of items with high poly counts (e.g., furnishings and equipment), I prefer to create those items anew in AC using the morph tool. Then they are native with fewer polys.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC25 USA on 16” MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) + 2 Asus ProArt PAU32C (4K)
