Collaborate forum
BimCloud 2020.2; Login name change and version support
mikas
Should I, as a master admin, be able to change a users login name? I f**d it up a little, and somehow I can't change the usernames of newly created users.
Users have not yet received their information, and neither have they ever logged in yet. Maybe I'll have to start over again creating users, and this time be more carefull with login name.
So is login name permanently locked after creating and saving the user information?
Couldn't find that info from the forums, nor from the BimCloud help online or BimCloud guide pdf.
AC25, Rhino6/7+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RX6800XT/W10ProWS
5 REPLIES 5
Noemi Balogh
Once a user is created, their usernames are not editable anymore. In your case, you have to re-create them.
Noémi Balogh
Customer Engagement Expert, Community Admin
mikas
That's what I did, thank you for the information.
mikas
Do I need to upgrade BimCloud 2020.2 to use it with AC 24 6004 FIN FULL project? I tried to look at it, but I got confused with all the versions and upgrades in there.
https://graphisoft.com/downloads/updates/BIMcloud_Updates
BIMcloud 2020.2 is compatible with Archicad 24 6004, but it is also a quite old version, which we do not support any longer. I strongly suggest to use the latest version, which is always available here: https://graphisoft.com/downloads/bimcloud
Also, please help fellow community members and open a new thread whenever you change topic. Thank you. 🙂
Noémi Balogh
mikas
Server is on MacOS Mojave, and it's a no go updating it right now. Later maybe.
ps. I changed the name of the topic to better correlate with my questions, and your answers.
Thanks again.
