Teamwork & BIMcloud
Bimcloud library multiple instances
I keep getting this error every time we send and receive in a archicad teamwork project. It takes up allot of time.
" some libraries could not be received, because their local copies cannot be overwritten.
Note: This might be caused by multiple instances of Archicad using the same BIMcloud library.
Any help??
9 REPLIES 9
Noemi Balogh
Hi eloise,
I suspect that you have two library parts stored under the very same name in one of your libraries.
Check your libraries and delete one or the other item - it should solve the issue.
Kind regards,
Noémi
Noémi Balogh
Community Expert, Admin
monster
Hi nbalogh,
I also encounter this Warning!
How to check which library parts are stored under the same name?
Thanks in advance,
Pawel
Noemi Balogh
Hi Pawel,
Usually these elements are modification and duplication of an existing object in your library. If you modified any elements lately, it may worth to check these.
Also, if you you extract the affected library's container (https://helpcenter.graphisoft.com/knowledgebase/25763/), you can check duplicates with Windows File Explorer / macOS Finder too.
Unfortunately it's a manual work, there's no easier way in ARCHICAD.
Kind regards,
Noémi Balogh
Mats_Knutsson
Kind regards,
Noémi
Hi. We get this error message from time to time. The error dialogue says another thing (not really sure what it actually says though... multiple instances of ArchiCAD using the same BS library...well that's the way Teamwork work...right!? The header in the error message says local library copies cannot be overwritten...and therefore recieve is blocked. Very confusing. I'm using the BIM-server libraries and don't bother about the local....is theere a technical explanation from GS about what actually happens when receiving and sending...I'm notafter the Delta blah blah but a technical/practical explanation.
/Mats
AC 25 SWE Full
Stuart Smith
I just got this error also.
I was editing a library part and tried to Save As... to save a copy onto my local drive.
However, the file did not show up in the folder I chose. It seems like it saved it in one of the local caches of the Libraries. Really confused about why it did this.
Now after Send and Receive, everyone else in Teamwork projects gets the same error and the Archicad Library 23 on our BIMcloud reads as 0 bytes and all parts from that Library are missing!
Needless to say this is a disaster.
v26 3010 USA
MacOS 12.6
AC user since 8.1
Stuart Smith
In our case, the solution was to delete the Archicad Library on the BIMcloud and re-upload it.
The problem was caused by doing a Save As... while editing a library part.
Instead of saving it to the location chosen in the dialog, Archicad saved it to the Archicad Library on the BIMcloud.
Bug?
v26 3010 USA
MacOS 12.6
AC user since 8.1
Noemi Balogh
In case of 0 byte libraries, I think the problem is caused by the Local Data Manager:
https://helpcenter.graphisoft.com/knowledgebase/119387/
If you experience Teamwork issue like this, and my tip doesn't help, I suggest to contact your local GRAPHISOFT representative for further support - it is possible the reason behind is something else.
Kind regards,
Noémi Balogh
What happens when we get a message box that says:
"Some Libraries could not be received,
overwritten.
"Two library items have the same relative location."?
Noemi Balogh
Hi fnsgreen,
We have a similar case in our system at the moment, but this is still under investigations.
Can you please contact your local support to open a ticket for your issue? Please collect an Archicad SUpport Package for them.
Thank you,
Noémi
Noémi Balogh
