Bug in zone tool: wall surface
Erwin Edel
I'm trying to determine the wall surface of a zone with a limited height for the ceiling, because obviously you won't be applying a surface finish to the parts above the ceiling. So I set the height of the zone accordingly. The volumes changes perfectly, I update the zone but the wall surface stays the same.
Some of my walls span several stories in my model. Zones next to these walls return the surface value of the entire wall element over the height of all those stories. It does take in account it's own circumference: horizontal dimension of walls have the proper effect, but vertical it's just wrong.
Is anyone else experiencing the same results?
Right now all my quantity take offs for wall surfaces are entirely unreliable.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
4 REPLIES 4
Erwin Edel
Wall over multiple stories:
www.leloup.nl
Windows 10 Pro
Erwin Edel
Wall on one story:
www.leloup.nl
Windows 10 Pro
Hi Erwin,
That problem has been spotted before. There may be a few workarounds mentioned on this thread -
http://archicad-talk.graphisoft.com/viewtopic.php?t=26982
Hope that helps.
Erwin Edel
Peter,
Thank you for pointing me in that direction. A forum search would've been smart I see, my bad!
I'll try the suggested use of Boundary Surface in schedules, it seems the most helpful fix for my deadline of upcoming monday.
I'm not one to ussually moan about ArchiCAD, but how this bug survived over 2 updates is a bit mindboggling.
www.leloup.nl
Windows 10 Pro
Learn and get certified!
