Bug report - surface cover fill doesn't update
POTS
Using Archicad 25, teamwork, when changing the surfaces, if the cover fill foreground is changed, next time the file is opened the setting are back to default. Hoping for a quick fix soon, to not waste time on these small things. Thanks !
AC 25 NED 6000 | WIN 11 | i9 + 32GB + RTX 2080TI
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you very much for the report and I am very sorry for the issue!
I asked our colleagues but we haven't received any similar report. Our first guess would be because the fills are placed inside a hotlink module, and the host file uses a different fill.
If it was not related to the case, I suggest reaching out to the local support with the Support Package for further investigation.
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Hi Minh,
For your information : it doesn't have to do with hotlinks. In this case its just a bug.
