2022-05-24 12:10 AM
Using Archicad 25, teamwork, when changing the surfaces, if the cover fill foreground is changed, next time the file is opened the setting are back to default. Hoping for a quick fix soon, to not waste time on these small things. Thanks !
2022-06-16 06:30 AM
Hello,
Thank you very much for the report and I am very sorry for the issue!
I asked our colleagues but we haven't received any similar report. Our first guess would be because the fills are placed inside a hotlink module, and the host file uses a different fill.
If it was not related to the case, I suggest reaching out to the local support with the Support Package for further investigation.
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-06-28 01:13 AM
Hi Minh,
For your information : it doesn't have to do with hotlinks. In this case its just a bug.
