2007-01-17 01:46 AM
2007-01-17 02:57 AM
2007-01-17 10:57 AM
2007-01-17 07:52 PM
Gor wrote:The most common reasons for getting this message are:
Hello! It's my problem:
I'm trying to save in Archicad 9 drawing to *atl (or *opt) file but a warning note appeared saying " Cannot write output file" What should i do?
2007-01-18 05:44 PM
Karl wrote:I did search zero height wall - and not found its.
1. zero height wall somewhere in your model (do a search - Djordje ran into this)
Karl wrote:I use Artlantis R and i have Export Add-on from ArchiCAD 9.0 to Artlantis R, that i downloaded from Abvent web site.
2. Make sure you have the most current Artlantis Out add-on.
Karl wrote:Maybe:) ... i try use only latin symbols in my model.
Since I see that you are from Moscow... it is possible that certain unicode cyrillic characters might be a problem?
