2013-11-20 11:30 PM
2013-11-25 12:34 PM
2013-11-25 01:49 PM
2013-11-25 05:59 PM
2013-11-25 11:06 PM
2019-02-01 05:49 PM
2019-02-01 05:51 PM
iburcar@grad.hr wrote:
Hi! I found one problem that some IFC type elements cannot be imported in COBie - especially ifcWalltype, ifcColumntype, ifcBeamtype. Did anybody had the same issue?
2019-02-01 05:53 PM
JBelk wrote:
I am trying to generate a COBie file from an ArchiCAD generated IFC using the COBie Toolkit 1.4.2 downloaded from the Graphisoft site. I am using a macbook pro. When I launch the application, the COBie Toolkit Starter window opens and I can initialise the system to populate the window with Java feedback. But what I am not sure about is where to go from here. How do you launch the COBie Toolkit Beta window with the 'Import/Export/Report' option?
Thanks
