2022-10-05 05:01 AM - edited 2022-10-05 05:36 AM
Hi everyone,
I am new to Archicad and I was tasked to route cable trays for a warehouse. I was provided an *.ifc file with the structure of the warehouse, which I hotlinked to a new project and saved it as a *.pln file. Then I routed the cable trays with at the correct height and exported the MEP Electrical layer as an *.ifc file.
When I open that *.ifc file, all of the trays are too low. And here is a possible clue to a solution: if the height of the tray itself is 60cm, then it will be too low by 30cm; if the height of the cable tray itself is 110cm, then it will be too low by 55cm - cable trays get lowered by half of their height.
I also tried to save cable trays as a new *.pln file by Save Selection as Module and saving it as *.pln file and in this case everything was well (but I need *.ifc files).
I am looking forward to hearing about beginner's mistake that I made 🙂
EDIT: I forgot to mention that on exporting to *.ifc I get a warning that there are multiple survey points. I do not know if it is important or not.
Best wishes,
Jakob
