CadImage Wall Framing Addon
I can't get this addon to work. I keep on getting errors when I try to apply framing or when I try attaching the wall framing object to Composites in Elements Attributes. I get them when trying to view the 3D window as well. The model looks messed up, or parts do not appear. This is a typical error, but the number of lines varies, with the same basic content though:
Pen number is less than 1 or greater than 255
at line 27 in the script of file Wall Frame 3D.gsm.
at line 46 in the script of file Wall Frame 3D.gsm.
at line 58 in the script of file Wall Frame 3D.gsm.
at line 82 in the script of file Wall Frame 3D.gsm.
What are these pen errors about? I tried to open the Wall Frame 3D.gsm file, but it seems to be made of three master files, so I don't know how to edit them.
I am using the latest version of the addon with the latest update with AC10 US.
1 REPLY 1
Hi Jason
As you will have already seen, I have posted you from our support email address some suggested solutions and an updated library to try.
Please let me know how you get on with this, to support@cadimagetools.com.
Regards
Learn and get certified!
