Cadimage roof tool
I have a strange problem: when ever roof plane's line's are not on 90° angle, ArchiCAD don't draw Cadimage part's like gutter, fascia... If you look at picture it is missing gutter, barge, fascia. As soon as I change angles between lines on roof plane, everything is normal and it shows all Cadimage parts.
Anyone have a solution?
Thanks in advance
Gerald Hoffman
Mickey,
You should contact CadImage support directly for this type of question. I have had good response in the past for issues that I have had. I have not had this problem that you show.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
OK, thank you for advice.
