Cadimage surface slider
The main door frame of Cadimage surface slider doesn't offset with the door leafs?
The main door frame should be offset and extend where the last door stacks.
Example Images attached
Could you model this using the exterior trim?
Possible, I'll take a look, it should however move the main frame to the outside and not leave it in the wall where regular slider would have it. I don't know how this gets past Cadimage, do they look at real life doors when they code this?
