Greetings,
I am unable to figure out how to create a parking calculation schedule based on measured areas and use categories input into zones. I tried adding a 'Use' property which one could select the ratio of stalls to area, but I was unable to make the calculation. It would be great to sum up the areas per use and then multiply against the parking ratio to return an answer of required stalls. Any thoughts are welcome. Thanks!
AC25 v. 5005 w/ MEP, Cadimage, Twinmotion 2021 using AC from AC6.0, 2.7 GHz 12-Core Intel Xeon E5 (OS X 12.2.1 Monterey), AMD FirePro D700 6GB, SSD, Artlantis 2019, Adobe CC. Used AC on both platforms.
