Gil wrote:
Q: Which part of the GDL object do you use to input the script?
I tried various places (Master Script, Property Script...), but
non returned the result needed.
Do you set up specific parameters ("plaster area") in the parameters
screen?
Create a separate property script object for the walls.
I do all of the calculating and outputing from the Property Script of that property object.
These can be linked "individually" to the walls in the wall settings or I have linked them to all walls in the "List Scheme setup".
If you use the list scheme then make sure you tick the box in the walls setting (Listing & Labelling) to "Link Properties by Criteria".
