Can anyone tell me the " error code:11010" means ?
archilai
It's show "Unhandled EDM exception - error code:11010!" on screen,when I save an archicad pla file as ifc2X3. Can anyone tell me the problem and how to fix it?
台灣來的建築師......an Architect From Formosa~~
Ed_Brown
Graphisoft Alumni
Graphisoft Alumni
The error message means your project was too big to export in one try. A routine could not allocate more memory to finish the export.
You will need to break your project into parts and export those separately. You might also look for objects that have an unusual number of polygons and either simplify them or remove them from the export if they are unnecessary for your specific goal.
In AC 16 hotfix 2 the ifc export was significantly improved. Many projects that could not be exported due to size in AC 15 can be in AC 16. You might want to try opening the project hotfix 2 of AC 16 and exporting from there.
Hope this helps,
Ed
Graphisoft Technical Support
archilai
Thanks for the answer, its very helpful.
