Can't Read PC CD with OS X
Dave Jochum
This is not AC related, but I've searched the Apple knowledge base, MacWorld forum, and this one, and can't find anyone else with this problem. I have a CD-R from a surveyor (on PC with ACad) with a project's survey in DXF format. When I first received it I could read it just fine. I'm not sure what version of OS X I was using at the time, but know it was prior to 10.3.2 which I am using now. Now my 'puter tells me the disc is unreadable. I doubt the disc has become corrupted, because it has just been sitting in its case in a drawer for the last couple of months, though of course it's possible. My CD drawer has occasionally been opening on bootup for no reason as well. Any Mac-heads have similar problems or advice?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
Dwight
Your best chance to read the CD is to put it in at startup.
Dwight Atkinson
Dave Jochum
Thanks, Dwight--it worked. I can't remember ever hearing that tip. Do you know why it works?
Dave Jochum
Dwight
I think that the system looks harder at startup - probably before any interfering extensions can insert a new, troublesome driver into the loading sequence that might select fewer format options.
I had some trouble like this once [obviously]. I discovered the technique because I left the unreadable disc in the holder. The next restart caused it to appear, hence the advice.
Another tip: If your G5 has a little red light on and the fans run only at full speed, your RAM is installed wrong. Guess how I discovered that.
Given enough rope, I would discover America by getting lost, but I think that it has been done.
Dwight Atkinson
