Teamwork & BIMcloud
Can't create BIMcloud project
Kuban00
I have a problem while creating teamwork project. Im installing BIMcloud menager and server with all the default settings. After that, and creating the user of the project i wanted to start the a new project. In the new opened Archicad 26 project i went through Teamwork -> Share and here comes the BIMcloud server window. I filled all the 3 blankets: Server Adress, Username, Password. (All were correct!). When im trying to connect , programs show "Cannot connect to server". What should i do? Does creating a new server could help?
I count on your assistance.
With all regards
Jakub
ryejuan
should be able to connect since you mentioned "All were correct"
Are you using BIMcloud Basic or BIMcloud AaS?
In the end what is your Objective?
ArchiCAD 9 onwards
I wanted to use BIMcloud, im using educational license, i couldn't find any information which i should use.
I want to create a server for a student project competitions, we are a four person team.
Szabolcs Miko
Hi @Kuban00, I'm Szabolcs, Education Program Manager at Graphisoft. Please reach out to us via email at edu@graphisoft.com. I'm sure we can help to find a good solution for you and your team to collaborate.
Szabolcs Mikó
