Cant see IFC file/data in 3d!
Can anyone help with an IFC problem. I have tried opening and also merging an IFC file into Archicad (v20) but cannot display the file in 3d. That is I can see all the information in 2d and can even generate sections but there is nothing in the 3d window even with a file zoom extents command. I found a solution before our recent holiday but did not document it and now cant remember what I did! AArgh!
1 REPLY 1
Hello KaeTi,
IFC is more than a 3D model.
There are so much parameters to translate before to import an IFC.
It's difficult to help you without knowing what you do before.
I invite you to :
- check your ifc import translator
- make visible all your layer in 3D view
- in 3D right clic and "show all in 3D"
Finaly clic on the little button like this one :
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
