SOLVED!
Circumference of Slab in Schedule
If I click on a slab, I can see a circumference in the Element Information palette. In a schedule, I do not see anywhere to select the circumference as a field. Is this possible? I would also like this number in a label but also don't see it as an available field.
Kris
1 ACCEPTED SOLUTION
Solution
Under General parameters, schedule the Floor Plan Perimeter. Interesting that Element Info uses the word "Circumference" vs "Perimeter".
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
3 REPLIES 3
Solution
I looked through all the properties several times and didn't see this. Looked for both circumference and perimeter. Thanks for the pointer.
I also see that I could have used the search as the top of the properties list. Lots to learn.
Learn and get certified!
