laszlonagy wrote:
Hi Paul,
I have not tried this out now, but I think this will be a very, very useful workaround for this situation.
Do you think this could also work for SketchUp imports? I suppose it would although in case of SketchUp one would probably do this by one SketchUp element at a time. But you may have more experience with it.
Hi Laszlo
I don't see why a similar process would not work for any imported objects.
The idea is that it edits a whole library of objects at once, assuming the same thing needs to be done to all - and imported dumb objects that display too many polygons would fit this category. You would probably start with one object to check what ArchiCAD import forgets to do automatically, then adjust the search & replace criteria accordingly for the XML file representing the whole library
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
