Hopefully someonehere will give a solution for your file that is easier than what I am imagining...
But, for the future: if you want someone with another copy of ARCHICAD to produce a file for you... regardless of what country version they have ... you really must give them your own template file to start from so that the file attributes - layers, pens, line types, fills, etc etc - will match your standards. You really must share your localized library with them (for Solo or Teamwork) so that you don't end up with library parts that will not work for you (unless they send you a PLA or use the embedded library of course - although even then there can be conflicts with your own localized library).
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
