Ah - I see.
No separate column values for each scheduled item.
The 'Value' figure comes up blank at first.
Sometimes if you type a width all columns will adjust - but sometimes not - especially after manually adjusting the width of one column.
But then it will work even after manually adjusting one column - sometimes.
Actually just noticed if you manually adjust some widths and then type in a width to adjust them all - but the figure you type is already the width of one of the columns - then nothing will happen.
The figure you type must be different to any of the column widths otherwise none of them will adjust.
