My test started inside a model checker. This is the reason I came back in Archicad.
I used Solibri and BIMVision.
The composite wall not cut and the composite wall not cat are translated in different way.
The composite wall cut is complex with al the boolean operation calculated. I'd like to have a simple wall like the wall not cut, only information with a simple shape.
Obviously this is only an example of a large project I'm working on. I Want to give my public client a simple model in IFC to check.
My next check is try to open it in Revit.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 25
https://www.archiradar.it/en/
