Composite wall build-ups - accurate material thickness
Jen M
See screenshot attached - is it possible to change the settings to reflect a more accurate measurement?
I'm trying to have the plasterboard 12.5mm thick rather than 13mm. It seems to always round up.
Thank you.
If you input 12,5 - then it is set to 12,5. How it is displayed is controlled by the working unit settings under options > project preferences > working units.
neilmcallister
It took me a long time to work this one out.  Of course, it is probably unlikely that plasterboard is actually manufactured to 0.5mm precision, but it is what it is sold as.
Archicad 26 / Windows 11
