2017-10-24 03:52 AM
2017-10-24 06:47 AM
Opening DXF/DWG FilesHope that helps, but they are running 14 year old software!
You can open DXF and DWG format files in ArchiCAD or PlotMaker as Drawings or Layouts. Choose File/Open and then select the file you need in the directory dialog box. The Translator Management dialog box appears. Here you can choose the Translator to use for converting the file.
You can also open a DXF/DWG file as a Library Part by choosing the File/GDL Objects/Open Object command. This will open the Library Part master window where you can configure the new object obtained from the entire file. If you choose File/GDL Objects/Import from DXF/DWG, the blocks of the translated file will be converted and placed in a new library folder.
2017-10-25 11:47 PM
2017-10-26 12:09 AM
Erwin wrote:That is a good point.
DWG trueview (free application from Autodesk) would be able to convert the DWG back to version 2010 or some such, as I would imagine 8.1 won't be able to open the more recent versions.
2017-10-26 12:52 AM
2017-10-26 02:33 AM
2017-10-26 02:45 AM
