Wow. Thanks for all of that hard work, Ferenc! The workaround is unfortunate, so hopefully GS will fix this in a forthcoming release.
A stupid question ... are you saying that it is not possible to do the translation without a DWG template file created in AutoCAD to define the AutoCAD text styles properly? If so, can you suggest a workaround if one does not have a copy of AutoCAD and the AutoCAD people that one communicates with are at too elementary of a level to create the template file? (I.e., is there an ArchiCAD-only solution?)
Thanks, and Happy New Year,
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
