Find the next step in your career as a Graphisoft Certified BIM Manager!
Converting a Archicad Model into a .STL file
cadsph
Does anyone know the easiest way to convert an Archicad model into an .STL file?
Also, I'm guessing the model would need to be scaled also say to 1:100 to be printed.
It's for 3D printing.
Andrii Levko
The easiest way is open model in 3D window and save as .STL file. On the Save 3D as STL dialogue choose  Binary or ASCII representation and set scale 1:100 or other scale what you need.
Andrii
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
Andrii Levko
Andrii
Andrii,
You are a LEGEND!
