Project data & BIM
Converting pln files from previous versions of ArchiCAD
What would be a good method of converting Version 7-Version 9 files into Version 12?
Eduardo Rolon
Convert 7 to 9 first using:
http://www.graphisoft.com/support/archicad/downloads/Fileconverter.html
Open 9 Files in AC12
Under AC12's Help select Reference guide and look for the section called "Migration Guide".
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
I appreciate the information - however unless I just flat missed it, I was not able to find a topic labeled "Migration Guide" listed in the in the ArchiCAD Help Index of Reference Guide Index.
Would you have additional information?
Eduardo Rolon
Wrong reference it is in
AC 12 Getting Started
AC27 US/INT -> AC08
another Moderator
