2015-05-22 03:09 AM
2020-07-23 10:00 AM
2020-07-23 01:47 PM
2020-08-30 08:42 PM
Da3dalus wrote:
We're still having problems with the font conversion, since we're now integrating Windows computers into our Mac office. We use a font called Swis721, which is similar to Arial/Arial Narrow, but much nicer. Even after it's installed in Windows, and the XReadCfg.txt is configured right (I checked it with tech support), it only works sporadically. Some computers, it's great, and sometimes, the fonts are substituted with something close, while others, the font substitution is illegible. All of these machines are identical and set up the same way! I'm a little rusty with Windows, but as far as I can tell, there is no way to control this default substitution in Windows 10.
I hate Microsoft so much. JMHO.
2020-11-18 06:13 AM
mnguyen wrote:Hi Minh, sorry I missed this message and didn't see your private message. I'm still experiencing this problem so please could you send the PM again and I'll send you the font files.
Hi Ash,
Thank you for the question and I am sorry about the issue!
I have sent you a link via Private Message, with which you can securely forward the file to us for further investigation.
Please let me know once you have finished uploading the file!
Thank you very much!
Best regards,
Minh
2020-11-18 12:59 PM
2020-11-19 05:50 AM
Sculptdesign wrote:Hello Ash,
Thanks!
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-02-18 03:19 PM
I found this thread while searching for a solution to this problem... not necessarily cross-platform, but when opening a file on a Mac with different fonts installed. I checked my XReadCfg.txt file, and it seems fine (showing the font Arial listed, which is what I want), however all my fonts got converted to something else when the project was opened on another Mac. Is there a way to bulk-modify all fonts in a file to one specific font? It would take a really long time to modify all objects and bits of text one by one. I see that tech support was helping people privately, which is great, but not very helpful for everybody else.
2022-09-20 02:31 PM
Hello friends,
well, as I worked on a individual Library (special objects for a customer-use) I have the same issue 😢...
I could not really understand, why GS do not deliver the different, local distributions (GER, AUT, AUS, ...) with the "local matching" Xreadcfg.txt to match the same fonts...
i.e. on MAC Arial is named "Arial" and the same font is named "Arial Westlich" in WIN-AUT-Archicad distribution...
...so why there are not the WIN-MAC "font-name pairs" of the most used fonts (Arial, New Times Romans, Arial Narrow, Swiss721, Tahoma, Verdana, ...) already in the Xreadcfg.txt included. GS do lots of "local adjustments", so why not in this case??
For most of us (users) everything will work fine, if the "SubSet" (Westlich, Grichisch, Hebräisch,...) ist matched to the localisation. so a german, austrian, swiss,.. localisation of Archicad (GER, AUT, CH,..) get "Arial Westlich" for Arial, a user of the greek-localisation (do not know if there is one 😏 ) gets "Arial Griechisch" in the localized Archicad Distributions...
I hope my English is not too weak - so you can understand what I mean...
looking forward to answers and perhaps discussion...
best regards from Viennna
Yours,
Klaus
