D3 Trim+Stairs-How do you do Custom profiles
Does anyone have this tool by Dimensions Design Group. See:
http://www.ddgi.com/object_shop/d3sp-shop01-libs-tr.html
Their manual is basically no manual at all as there is not even the most basic level of directions.
I've called them and emailed them and they won't respond on even a courtesy level.
So this forum is my last ditch effort.
Does anyone know how to create a custom profile for their tool?
I've tried doing the method I am accustomed to doing when I make a custom door or window for Archicads library, but that hasn't worked either.
Has anyone had success making a custom profile for this tool?
If so, will you please enlighten me on how to do it?
Thank you.
1 REPLY 1
vincon2 wrote:
...Does anyone know how to create a custom profile for their tool?...
Vincon2,
I haven't used these objects for several years, but I seem to recall that the various profiles are macros called into the objects. So....bottomline you would probably need to script a new trim macro to be called into whatever object you are using....not for the faint of heart.
Dan K
