Project data & BIM
DUPLICATING A LAYER COMBINATION
Is it possible to duplicate a layer combination so that I could be able to only change a few show settings?
EDIT: or is it when you create a new combination it duplicated the one currently selected already?router-help.com
When you create a new combination, it will use the current settings for the for the layers - so if you select an existing combination first then yes it will duplicate the exact settings of that combination.
Barry
Eduardo Rolon
And if you want to edit both at the same time you need to use Attribute Manager instead of the Layers Palette.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
