Collaborate forum
DWG AC24 translator "explodes" all objects into lines...'No bueno'
rob2218
I'm posting this question up for a friend.
Seems when he uses the AC24 DWG translator...it's 'exploding' all objects into individual lines, arcs, little pieces and segments of lines....and his engineers are having a heck of a time with the DWG file.
Is there a setting in the translator he is missing from toggling on or off that prevents this from happening?
thanks for the help.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
There is no single "AC24" translator. Like everything, a DWG translator is a very customizable thing... and depending on the localization, you will have some pre-built translators that may either be useful as-is, or may be a start for further customization specific to the required need.
Attached are two screenshots. One shows the pre-installed, sample translators provided in the USA installation. Notice the "Description" field contains documentation to describe how the given translator should behave. In particular, though, see the "Saving Floor Plan" option screenshot. It sounds like your client has this set to "Explode ARCHICAD Elements" rather than "Convert ARCHICAD Elements to Blocks".
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
rob2218
thanks a heep Karl.
I'll pass this on to them.
much ablidged.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Thomas Holm
I’d like to add:
—You should be very careful when selecting the export objects as blocks option. Always examine the exported DWG thoroughly.
In our AC24 5003 SWE there seems to be a bug in the DWG export translator: the resulting blocks don’t contain any of the modifications or customizations we’ve made to the Archicad objects. They export with their default appearance, dimensions etc. (Except when they just create havoc in the dwg file).
We’ve resorted to only export with the explode Archicad objects option checked. This at least preserves the intended appearance of the objects.
We always export with the Keep pen index number translator, never Bylayer, and set to AutoCAD 13 as target.
AC4.1-AC24SWE-25INT; OSX11.5; MP5,1+MBP16,1
