papsphilip wrote:
The problem is when archicad exports fills to autocad we ve had complaints that its unusable.
What makes them unusable?
What problems is the Autocad user having?
I am no expert in this field as I have little need to export a lot of views to DWG - just a few for which I have a Graphic Override to make all cut fills and zones transparent.
Maybe it is your translator setup.
I would "export all fills as is"
Do not export fill backgrounds as additional solid hatches.
Do not explode gradient fills.
These seem to be the only options you have.
There must be a 'happy' setting otherwise every one would be having the same problem.
If that doesn't work then (apart from the Graphic Overrides) you would need to set up a fill/hatch conversion table for each Archicad fill to the same Autocad hatch.
Then maybe the Autoacad user could easily selct and delete them?
