2014-02-18 09:52 AM
2014-02-18 01:18 PM
Erika wrote:Erika, are you sure about this?
It's a work around, but quick to do and undo when you work.
In archicad set the DISPLAY of the walls containing the columns to 'bring to front' then they will cover the columns and the DWGs will export correctly.
Select the walls > right click>Display order>, bring to front
HTH
2014-02-18 01:56 PM
2014-02-18 08:40 PM
laszlonagy wrote:Yes, I tested it out. As you pointed out earlier, the DWG is created from what is seen on the screen.tErika, are you sure about this?
HTH
I think this is not the way it works when the Column cuts itself out of the Wall as shown be the images attached to previous posts. The Column will be cut out no matter where the Wall and Column are in display order relative to each other. At least this is how it works for me in AC17.
2014-02-18 10:35 PM
2014-02-18 10:37 PM
2014-02-19 01:03 AM
