Collaborate forum
DWG Exports
khairulfikri
Hi!
I'm having trouble with exporting to DWG, specifically with lines generated to represent walls.
Our colleagues in the Middle East insists on working in DWG, and drawings set up in such a way that they can switch layers off individually (i.e.: external wall finishes can be switched off independently of the blockwork). It's a tricky one since we've modelled walls as composites and separating out the skins into separate layers is a bit of challenge.
I've set up the translator to generate DWG layers by pen numbers, and modified the composites to use line pens and fill pens specific to the layers the skins need to be on. That seems to work fine (albeit a bit time consuming to rework the model to make sure there aren't "stray" layers). However, there seems to be an issue where walls intersect columns in that the lines representing the wall in DWG are trimmed, but the ends of the trimmed walls are left open (with no line representing the end of the wall meeting the column). I've set the "wall end lines" switched on so I would've thought the lines should automatically be shown in DWG.
Am I missing something?
Also out of interest, does anybody have a better way of exporting to DWG and separating composite skins on different layers?
...it's all fun and games till someone loses an eye..
ArchiCAD 19 | Mac OS X 10.9 | iMac 2.9GHz Intel Core i5 | 20GB RAM | NVIDIA GeForce GTX 512MB
15 REPLIES 15
I was going to recommend using the Layer by Pen Numbers option but I see that is what you are using.
Could you post two screenshots of this problem?
The first should be a typical problematic situation in ArchiCAD, the second should show the result in the DWG file.
(AC-Talk will let you attach only one image per post).
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
khairulfikri
Thanks Laszlo.
Here's a screenshot in Archicad, with columns switched on.
khairulfikri
Here's a screenshot in Archicad with the columns switched off. You'll see that the walls have been trimmed by the columns where they meet, but there is no end line to the walls.
khairulfikri
Here's a screenshot in Autocad, with the columns switched and hatches off. Again, the green lines representing the blockwork skin of the wall composite are trimmed but no end lines where walls meet columns.
This might be an oversight on the part of the programmers.
Those lines are part of the Column geometry and there is no problem with their display when the Columns are shown.
You can see that it is already a problem in ArchiCAD: those lines do not show when the Column is hidden even in ArchiCAD.
The DWG Export only exports what is on the screen so I don't think that is a DWG export issue.
I will let the developers know about this.
Unfortunately this also means that I cannot offer much help or solution.
I can only offer a workaround: create a copy of the column and exploded it, then use the lines generated from the exploded geometry for the missing lines, assing them the same Layer line type and pen as the Wall they belong to.
khairulfikri
That's a shame. There is another workaround that I was going to use but was really hesitant - draw 2D lines in plan where columns meet walls. It's laborious and opens up the risk of mistakes when changes happen.
Hopefully this oversight can be addressed quickly?
Thanks.
Erika Epstein
It's a work around, but quick to do and undo when you work.
In archicad set the DISPLAY of the walls containing the columns to 'bring to front' then they will cover the columns and the DWGs will export correctly.
Select the walls > right click>Display order>, bring to front
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks.
I really don't know how much time it will take to address this. As far as I remember this is how the program has been woking for a very long time.
Erika Epstein
Coversly select all the columns you want to hide and send them to back.
HTH
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
HTH
Erika, are you sure about this?
I think this is not the way it works when the Column cuts itself out of the Wall as shown be the images attached to previous posts. The Column will be cut out no matter where the Wall and Column are in display order relative to each other. At least this is how it works for me in AC17.
Eduardo Rolon
Just a though.
Change the Layer Intersection number so that the columns and walls do not intersect?
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Erika Epstein
laszlonagy wrote:
t
HTH
Yes, I tested it out. As you pointed out earlier, the DWG is created from what is seen on the screen.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
khairulfikri
Thanks Erika. That seems like a workable work around, though it would produce DWGs with walls continuing through columns, which in my experience with these guys in the Middle East is not something they're looking for.
I suppose another work around is to literally stop walls in either side of columns. Again it's rather laborious but better than drawing little 2d lines everywhere.
khairulfikri
Laszlo,
Should this be an item on the wish list then?
Probably or possibly.
If it is never wished for there is little chance it is ever going to be changed.
