2004-01-28 09:21 AM
2004-01-28 09:35 PM
DennisG wrote:Are you opening in ArchiCAD or PlotMaker? If you are opening in PlotMaker, then your DWGs should come in as they are - model data in PMKs, paper data in Layout space.
Greetings;
A consultant has sent me a number of DWGs, consisting of a mass of info in model space filtered through viewports so that the only way to make sense of it all is to view the DWG in paperspace.
PROBLEM: in the translator, "Import Drawing Data from:" the option for "Paper space with viewport contents" is greyed out. When I try opening the DWG, all I get is the paperspace contents - basically an empty sheet with titles.
Please help - I've got to get on this today. Any and all suggestions are greatly appreciated.
Dennis
2004-01-29 02:56 PM
Djordje wrote:DMG: Most definitely - thanks.DennisG wrote:Are you opening in ArchiCAD or PlotMaker? If you are opening in PlotMaker, then your DWGs should come in as they are - model data in PMKs, paper data in Layout space.
Dennis
DMG: Meaning either paper space OR model space, but no Paper space w/viewport contents.
Paperspace with viewport contents is availabel only in ArchiCAD, and it should be opened at 1:1 in the units specified in the PaperSpace (usually mm in metric world, inches in imperial world).
DMG: OK, I think I get it now😉
Warning: what you get is SCALED viewport content!
DMG: I've been warned...
Now, the real question is, what do you have to do with those drawings? The answer to his is what decides the strategy.
DMG: All I want to do is print them to half-size via my HP 122C printer. I am resisting strongly the urge to fire up my copy of ACAD 2000 and do it that way.
HTH,
2004-01-30 03:09 AM
