2004-05-05 04:13 AM
2004-05-05 07:48 AM
ELL wrote:Off the top of my head - what is the fill status in your file? Too much vectorial ones? True weight or hairlines? Are the Xrefs cleared and purged?
I am trying to use default translator in AC 8.1 for 4.7 MB Site Plan pln file and save as dwg file. There are three x-refs attached to this file for three small buildings (2 MB; 1 MB & 1 MB) which were done on AutoCAD. Problem is program starts translation and indicates 54 minutes left, and then it gets locked up. I have used translator several times before on files with multiple x-refs and pln hot-links, but have not run into this problem. It has always worked well in the past with very timely results.
2004-05-06 09:35 AM
