2020-07-05 04:18 PM
Solved! Go to Solution.
2020-07-09 01:50 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-07-09 07:01 PM
2020-07-10 07:00 AM
2020-07-10 11:54 AM
mnguyen wrote:Hello mnguyen,
Hi Avi,
Thank you for the question and I am sorry about the issue!
Unfortunately, AutoCAD 2007 is quite old as of now, therefore I cannot get a copy of it. What I would like to check is the fills missing in the black display. I'm wondering if you can open the file with a newer version of AutoCAD? If not, could you share the DWG with me for further investigation? Let me know if you'll need a secure link to send the file!
Looking forward to hearing from you!
Best regards,
Minh
2020-07-10 12:00 PM
sboydturner wrote:Dear sboydturner,
Avi,
this is an AutoCAD issue not an Archicad issue, in Autocd you need to select all the hatches as you have them exported as blocks and explode the blocks from there you can edit the properties of all of the hatches.
Just as an aside, why are you exporting to AutoCAD? If it is for a consultant or trade etc for coordination / shop drawing etc why are you worrying about how it displays on their end they should be thankful that you have provided them a base from which to work.
Reagrds,
Scott
2020-07-10 12:21 PM
Minh Nguyen
GRAPHISOFT
2020-07-10 03:34 PM
mnguyen wrote:
Again, let me know if you need a secure place to upload the file!
2020-07-10 03:49 PM
mnguyen wrote:
I believe there was a problem in the file/translator, as some fills exported as block still have the correct color. Could you share with me the PLN that you used to export the DWG, along with the translator used for export? Again, let me know if you need a secure place to upload the file!
Minn
Here is The PLN file.
https://drive.google.com/drive/folders/1ZH5dXZ71W1hi45uxo0vnniySUrDTxKqF?usp=sharing
I used "SB-Translator for further editing" to translate this file. (See Fig -1)
Avi
2020-07-11 09:04 AM
