DWG export for Dummies
David Collins
I'm trying to send a DWG to an engineer and we're both pretty dumb. He says the DWG I'm sending him is blank.
What's the most bullet-proof no frills no nonsense method for translating to DWG for AutoCAD? What are the most common mistakes dummies like us make doing this?
Thanks
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
6 REPLIES 6
Link
The US version actually has a translator called DWG for Dummies
Link.
David Collins
The INT version leaves that one out.
I don't know whether to feel insulted or complimented, but it sounds like exactly what we need.
David Collins
Eduardo Rolon
here you go
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
David Collins
Brilliant.
Still a dummy, but I'm starting to find my way with these things.
Many thanks.
David Collins
Graham Whipple
I found the dwg export for dummies, hoping it would solve my problem. I don't consider myself a dummy, but I am working with an engineer who claims the dwg files he is receiving are locked, restricted, read-only and not editable even through copy clip and paste.
has anyone seen this happening? After 15 years of exclusive ArchiCad use I no longer have AutoCAD to test this behavior. I've never had that feedback from an engineer in 15 years. There have been other snags, but not in recent years.
Any insight on the possible issue is appreciated.
Graham Whipple
Resin Architecture
Idaho USA
Eduardo Rolon
Download DraftSight it is free, Mac and PC, and compatible with AutoCAD
http://www.3ds.com/products-services/draftsight/overview/
AC27 US/INT -> AC08
another Moderator
