Kristian,
The problem with the method you describe is that you have very little control on how the inserted drawing displays. We want to be able to publish the information so that it appears as part of our drawing and looks unified rather than a miss-mash of drawings to different standards. If it was just a case of inserting and trace what you need the inserted "drawing" method would be fine. I'm expecting something a little less "old school cut and paste" and a bit more incorporating other's data.
The DXF-DWG Translation Setup has not changed in the way it works for quite a while now and while ArchiCAD is pushing the exchange of information bandwagon this process should be simpler.
Thanks for the suggestion anyway.
Matthew Johnson - P O W E . Architects
AC25, Windows 11 64bit
Dell Precision 5520 i7 w/ Nvidia Quadro M1200 4K dual
i9-12900K w/ Nvidia RTX 3080 4K
I'd rather be sailing.
