Deactivate Analytical format entered / output Extension
I had to pass a PLN 24 project in version 22 for the needs of a colleague. When opening my file it seems that an extension managing the structure is missing. Can I hope to disable this missing extension from AC22 or do I have to perform this operation from AC24 ?
I'm already looking for an AC22 solution...
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
If you mean that you get a dialogue box when you open the file in 22 that says an add-on is not available, then you can either ignore it (but it will appear again next time you open the file, or you can un-tick the box for that add-on and the information related to it will be removed and you won't see it again next time you open the file.
SAM (Structural Analytic Model) is a new feature in version 24 that does not exist in 22.
So that information is lost anyway.
I'm wondering if just disabling the extension from the alert window when opening the file would not be enough.
Christophe - FRANCE
Yes that's what I thought. I have written here a little too quickly.
Thank Barry for your support.
Christophe - FRANCE
