2020-12-14 04:05 PM
Solved! Go to Solution.
2020-12-22 06:39 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-12-23 10:02 AM
mnguyen wrote:Hello Minh,
Hi Nathan,
Thank you very much for your report and I am very sorry about the experience!
This is the first time I saw such a report! May I ask which Archicad version you are using? Please make sure to have everything up-to-date.
I would like to know whether there is anything special with the file? Can it be reproduced with another file, using the same DWG as Xref?
Looking forward to hearing from you!
Best regards,
Minh
2021-01-04 04:00 AM
Minh Nguyen
GRAPHISOFT
2021-01-04 04:30 PM
mnguyen wrote:Happy New Year to you as well! I actually just got back into the office today, so your timing is perfect. Yes, it would be great if I could send the file your way so you could inspect it. If I could upload it to you using your secure method, that would be awesome. How should I go about that?
Dear Nathan,
First of all, Happy New Year! May it bless you with health, wealth, and happiness!
Thank you very much for the information and I am very sorry for the late reply due to the holiday season.
I tried to replicate the issue on my end using Archicad 24, but it works correctly in my case. May I ask for the TPL file from your side for further testing? Please let me know if you need a secure place to upload the file also.
Best regards,
Minh
2021-01-05 01:55 AM
Minh Nguyen
GRAPHISOFT
2021-01-10 11:38 PM
Minh Nguyen
GRAPHISOFT
2021-01-11 09:17 AM
mnguyen wrote:Great to know Minh. I turned all of my layers on, and was able to successfully detach my XREFs! Thanks for your help.
Hello,
I will share the result from our developers' investigation here in case someone might experience a similar situation:
The developers found that the Xrefs not being detached has something to do with the layer visibility. If we make all layers visible, we can successfully detach all the Xrefs. So this can be a workaround for now. Unfortunately, we don't know what caused this issue in the first place.
I hope that it will be helpful if you are having a similar situation!
Best regards,
Minh
