Chris wrote:
Thanks Thomas, but unfortunately it still reads as the entire mesh.
Any other ideas?
Works perfectly for me, Chris. Check your 3D to verify that you did the subtraction - the difference between the original mesh volume and the final volume is your displacement. Also - are you sure you clicked on the volume button in the Element Info palette?
Another way that just worked fine for me now and does not require the subtraction is to duplicate the mesh, duplicate the lowest slab (or create one) - both on a normally invisible layer of course - make the slab tall enough to be stick out of your mesh completely, and then use the Intersect operation of the SEOp palette. The resulting piece of mesh will have the volume of your displacement.
Often, I use two meshes anyway - the survey mesh, and then an editable site mesh that I adjust to show fill. Subtracting one from the other leaves the fill - for which ArchiCAD instantly gives the volume. I use different cut fills for each so that fill vs original soil shows up in section. Sometimes I use a slightly different grass material on one vs the other, too, to see where fill is going in OpenGL and renders (obviously working renders, not presentation).
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
